Camera Offline
  • 1 Reply
  • 991 Views
SteveEEE
Hi. I have several essential spotlight wifi cameras - VMC2030A. One has gone rogue and the app says it is offline with 1% battery. But it is charged and if I try to add it as a new camera it will chime at the QR code but then not be found. Any ideas, please?
Did you remove the camera from your account before trying to re-add it? Use this FAQ's process to remove and reset the camera.
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
  • 1 Reply
  • 991 Views
