Arlopro 3 Keep getting the black screen on 2 out of 4 cameras
Keep getting the black screen on 2 out of 4 cameras (spotlights seem to work) can hear but cannot see anything. When I do get picture it again goes black if I try and make the screen bigger. Very frustrating as it is generally hit and miss if the camera works and is almost inevitably when I want to actually check the camera for a reason. Also if I try using the Mic to talk the camera disappears so I am talking blind! I already have a cellphone!! Why is this expensive system so unreliable??
RegR,
What model mobile device are you using? Do you see the same behavior if you live stream using a different device?
RegR,
Do you see the same behavior if you test using a different device to stream?
