Hi, very random issue that has happened. I set up the Arlo 3 system, created an account as I'm supposed to, a guest then came to visit set up an arlo account and somehow has hooked up to the smart hub. Now when I log on it says the cameras are off line. How does this happen?
I assume you're still logging in as the primary user? Have you rebooted the base and your phone? Does the visitor see the cameras? Are you getting recordings?
