Arlo pro 3 - Camera wont resync with hub
I just purchased this unit yesterday and got everything working just fine. Then i accidentally removed my 2nd camera from the app. I have spent all day trying every combination of sync buttons on the hub and the camera with no success. It sounds like this is a reoccurring problem across all of these cameras(pro2 ect.). Does anyone know how i can get my hub to see this camera? i havent found an answer from other posts.
Only you know what combinations you tried, did that include pressing the sync button until it showed three orange flashes?
Did you also find this?
How do I reactivate a camera that I deactivated?
Just another user
I looked and the second camera isnt listed
Just tr held the resync button till it flashed orange 3 times it continued to flash blue several time while trying to sync, still no luck
68ford,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
