Arlo Support - net able to get phone call back
I am beyond frustrated because I have tried to contact phone support at least 10 times about 2 of my 4 cameras constantly going off-line. I give them my phone #b ut never receive a call. My phone works and ringer is on. 5 minutes later, I receive an email from Arlo saying that they tried to call but I didn't answer. I have tried to use the online support but it must be a computer generated response and never comes close to answering my question.
Has anyone else had this trouble with them trying to all but you not actually receiving the call?
I really would like a phone # where I can call them but I cannot find one anywhere.
I’ve never had to call them but I definitely feel for you. Odds are they’ll tell you to turn it off and then on again and see if it helps.
This seems to be a trending issue with these cameras and the posts I’ve read really have no definitive answers. Most say that the problem just eventually stopped.
If the cameras are constantly dropping offline, this is likely an issue caused by interference or the cameras location.
Take a look here for positioning tips: https://kb.arlo.com/37/Arlo-Camera-Placement-Tips#:~:text=Elevate%20your%20camera.,manual%20for%20pl...
If you'd like to contact support to further investigate the issue, be sure to use the mobile app under Settings > Support.
