Arlo Pro3 constant false alerts at night
  • 2 Replies
  • 1542 Views
  • 2 Likes
Jenguran
During the day everything is great, activity zones seem to work perfectly. At night it's constant alerts. Any time a car drives by, if the splash from their headlights hits anywhere in my yard, alert. I contacted Arlo tech support, they were mostly useless. Had me turn the sensitivity down to 40, which solved nothing.
These replaced a set of Lorex cameras that didn't do this. I'd maybe get 1,  sometimes 2 false alerts at night but that was it.
I got 3 false alerts while I was typing this. Anyone else have this problem, or a solution?
Positioning your cameras differently may help, too. Many folks try to get too large a view for the cameras, leading to false triggers. Rotate them down to remove areas of no real concern. Remember that people can only be detected out to ~25 feet so any view beyond that may be excluded.
K80Shooter
Virtuoso
Virtuoso
Yes this does happen and yes it does it with mine. The only solution is to point the camera in a different direction or in smart notifications disable other motion for alerts. I have mine set for people only. You'll still get recordings but no alerts.
  • 2 Replies
  • 1543 Views
  • 2 Likes
