I have the Arlo Pro 4, base/hub model VMB4540 and 3 cameras. For several weeks my smart hub has been showing offline and the LED is blinking amber. I have unplugged everything and plugged it all back in (several times) and I've done a hard reset and it's still blinking amber. When I looked through Arlo's suggestions to fix, LED "blinking amber" isn't an option. Has anyone experienced this? Any suggestions?
Thank you
It's possible that rebooting your router and hub, in that order, may help. The FAQ about the various LED modes shows:
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
It's also possible the hub is faulty. If you have a subscription, use the app to go to Settings, Support and choose your hub. Scroll down to Contacts to see what official support may offer.
