  • 11 Replies
  • 2226 Views
  • 5 In Conversation
nics
I own the “Arlo Pro3 2K QHD Wire-Free Security Camera System - 3 Camera Kit”. Purchased from Costco. One of my camera’s spotlight comes on a few seconds then turns off, at night for no reason. This occurs many times at night. There is no motion detected and does not record anything when the spotlight comes on. I know the spotlight comes on and goes off because I have a different brand camera facing the same way and it sees the light go on and off by the shadows it creates when it goes off. I am unable to attach the video because the extension is not supported here. My questions, why is this happening? How do I fix/repair this issue? Is there a fix? Is there a problem and/or need to new camera?
Thank you,
Nic
11 REPLIES 11
You can post links to the video but not the video itself.
I've seen the "light comes on briefly at night" issue for years on various cameras. I can't explain it but I suspect it has something to do with checking for updates or similar.
I have an Ultra which has been turning on the flood light since I got it ( almost 2 yrs )...
It comes on about 2-3 am for about 2 secs every now and then. I also see it from another camera that is powered all the time.
It has been investigated and it does have something to do with the camera checking itself.  ( out of your control, so nothing to fix ).  I have not seen it make really any difference in the "life" of battery.
Assuming you are having some what of the same.
Shaun1234
Virtuoso
Virtuoso
I have this happen, believe it or not its the infrared turning on and off intermittently, you cant see it but the other cameras can, you can test this by toggling the night vision on and off and see what the other camera recorded
Shaun1234
Virtuoso
Virtuoso
And the infrared can really light up an area and look like a spot light through another camera
nics
jguerdat,
Thanks for the reply.
Regards,
nics
nics
Thanks TomMac for the reply.  I did notice my battery life is still consistent with my other cameras.
v/r,
nics
nics
Shaun1234,
That is an interesting observation.  I will look a bit more into it.
Thank you,
nics
Shaun1234
Virtuoso
Virtuoso
No worries, i am still amazed at how it works, even creates shadows. My work colleague has a set of different cameras and they can also see each other's infrared.
Yes... with multi cameras the IR illumination will appear as a bright light to another camera.... so it is possible you can think it is the flood light.
I see it every now and then with indoor cameras too, as one turns on at night and the other camera sees it.
I'm having the same issues but I don't think it has anything to do with night vision. When my spotlight comes on, you can tell it is the spotlight and the night vision because my spotlight always illuminates in color when it does and the night vision is never in color without the spotlight.
nics
Good morning!  Sorry for late reply.  I agree it has nothing to do with night vision.  Your issue is what happened to me too.  I never found out why.  I can tell you that it has stopped.  I don't know why. It appears that it just fixed itself.  As of right now (19 May 2021), it has not repeated the issue.
Again, sorry for late response.
v/r,
Nic S.
  • 11 Replies
  • 2227 Views
  • 5 In Conversation
