Arlo Pro 3 not being synced after battery recharge
I tried all of the options displayed on the forum and articles provided by Arlo.
I think the issue is I’m unable to reset the camera by holding sync button on camera and I don’t get an AMBER light at all. I always get Blue LED.
I also tried changing the battery from the running camera and resync the camera but No Luck !
please do the needful.
thanks
How long did you hold the sync button to reset? It has to be >10 seconds to be sure.
I tried for a minute to resync it.
i tried all possible options according to my best knowledge.
only issue I come across is AMBER light is not happening.
Use Settings Support and choose your camera type to possibly start a replacement process.
