Arlo Pro 3 low battery
  • 1 Reply
  • 419 Views
drollinger
I have 2 batteries bought in april. They charge to 99% not 100%. Camera blinks blue and sometimes takes one picture but then turns off indicating a low battery. I have an old original battery that works with the camera. If I place the new battery in another camera, that camera will not work. Battery appears to be bad but charge indicates it is OK.
ShayneS
Please reach out to the Support Team to further investigate this symptom you are experiencing with your battery. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
ShayneS
  • 1 Reply
  • 420 Views
