Arlo Pro 3 is dark at night
  • 1 Reply
  • 615 Views
Kevismo
I mounted the camera under the corner of the home. During the day the camera works fine. At night it’s dark.
I have toggled night vision and adjusted low light setting, neither work.
I’ve also tried motion detect with spotlight which also doesn’t turn in when tested at night.
Any help is appreciated. Thanks!
Remove the camera from Settings, My Devices. Use the camera reset procedure found in the support FAQs, reconnect it and see if that helps.
  • 1 Reply
  • 616 Views
