Arlo Pro 3 in Syria
Hello,
Is it possible to use Arlo Pro 3 Base and 3 cameras in Syria? Can I avoid the Geo Lock by setting up the system in the US then take it with me to Syria to install it there? would the Cloud work this way?
I love Arlo, they are the best system out there and wish to protect my Syrian house there and my elderly parents.
You thought to set up the system in the US and then transfer it is the only way for this to work. Be sure to use a US credit card for subscriptions, too.
Do I need to buy subscription immediately before I travel for Christmas, even with 3 months of free trial?
Can I later buy the cloud subscription when I return to the US?
Thank you,
You should be able to add subscriptions at any time since the system was set up in the US.
