  • 2 Replies
  • 1890 Views
ohuk
Whenever motion is detected by my Arlo Pro 3, the camera turns the LEDs on very brightly. This is very undesired behaviour, I really want the camera to just start recording quietly and without the bright light shining, and not give off to the subject detected that something is watching it. I can't find any settings for that, is there  any way this can be done? The "LED off" setting is not relevant here.
Thanks in advance!
If you mean the spotlight, then you'd go into low light settings and turn off the spotlight and low light color vision there. (Also turn on NightVision).
There are also some red LEDs that providing infrared illumination for NightVision.  Turning off NightVision would keep those off, but you wouldn't get useful recordings.  FWIW, I wouldn't describe those as "bright", so I am thinking you actually mean the spotlight.
In any event, the camera needs some form of light when it's dark outside.  Another option would be to illuminate the space with floodlight at night (not motion activated).  Then you could disable both the spotlight and Nightvision, and still get useful recordings.
ohuk
Fixed - thanks 🙂 !
  • 2 Replies
  • 1891 Views
