Arlo Pro 3, Wifi booster?
Retired_Member
Not applicable
2020-12-03
12:25 PM
The wifi signal being indicated on the unit at the front of my garage appears to be weak. How can I boost the signal?
You can relocate the base closer using a wifi extender or powerline extender that has a ethernet port. Also a second hub/base if that effects the other cams connection.
