  • 1 Reply
  • 1727 Views
Eyemd818
So one of my cameras doesn’t seem to have its spotlight or infrared working.  Battery charge is 75%.  Under video settings both are turned on. Camera is about 3 months old.  I do live stream and turn on the flash icon but camera fails to turn on its spotlight.  Help here? Or do I contact customer service? If so what is the number? Thank you.
I'd start by removing and then reinstalling the battery - that reboots the camera.  If that fails to resolve it, you probably need to do a factory reset.  https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
There is a support area in the app (just select "settings" and you should see it).  That will give you the support options for your camera.
  • 1 Reply
  • 1728 Views
