Arlo Pro 3 Floodlight Camera
  • 1 Reply
  • 937 Views
Ironmanx
I am thinking of purchasing an integrated Arlp Pro 3 Floodlight with camera and have a couple of questions if someone could help me:
1.  How long does a rechargeable battery last.
2.  Is it worth buying the solar recharger.
3.  is the footage from the camera saved somewhere?  If it is how far back can I retrieve footage from the camera (if I do not pay the Monthly Service Fee)?
Thanks in advance!
That depends on a lot of factors - the amount of motion in the area, temperature, quality of the wifi connection.
Mine lasts about 10-12 weeks.
If there's an area near the camera that gets enough sun, then it can certainly extend the battery life.  Note that the camera won't charge when the temperature is below 32 F
You can always add the charger later.
The alternative to getting a subscription is to use direct access to local storage.  This requires using a VMB4540 or a VMB5000 smarthub.  https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are several limitations
  • recordings can only be viewed in the app (not the browser on a PC)
  • recordings can only be viewed from the primary account (not "friend" accounts)
  • manual recordings can not be saved
  • no thumbnails
  • remote access either requires setting up a VPN or port forwarding in your router (which many find difficult).
  • 1 Reply
  • 938 Views
