Arlo Pro 3 - Cameras offline
Hi my Pro 3 cameras have been offline for the last 6 days.
Initially the smarthub was offline too but this came back on when turned off and on again
Have tried removing and reinserting the batteries for the cameras but no success
Also attempted manually syncing but thats not working either
Base station LED is flashing orange as are the camera LEDs
Appreciate any help in what to do next
From the FAQ https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean:
Solid Amber. An error has occurred or something is wrong with the connection.
Slow Blinking Amber. The camera connection can’t be found, is out of range, or some other connection error
Sounds like a connection signal strength/quality issue which has worn down the batteries in the cameras. Charge the cameras and try positioning the hub so the signal strength improves.
