  • 1 Reply
  • 863 Views
7474
How to run two separate installations on one device? Understand impossible download two apps on same device. I’ve two separate installations at two locations far away from each other but would like to have access to both via one single device, not as now using two different devices. Can I solve the problem by “granting access to a friend” for one installation while running the Arlo a
Yes (and you should grant access rights when you do this).
FWIW, you can do this in both accounts (allowing both to see all cameras).
  • 1 Reply
  • 864 Views
