Arlo 3 Pro solar panel compatibility
  • 4 Replies
  • 3091 Views
SimonFurtner
I purchased an Arlo 3 Pro system and also the Arlo Ultra Solar Panel Charger (VMA5600-10000S) as it shows as the recommended solar charger. I connected the solar charger to the camera, but it doesn't show a charge. My question is: Is this charger actually the correct charger for an Arlo 3 Pro and if it is, is there are trick to set up the solar charger (I tried to simulate the sun by a lamp, but nothing happened).  Thanks!
SimonFurtner,
The VMA5600 is the correct solar panel for your Arlo Pro 3 system. For more information on how to set up the solar panel for best performance, take a  look here:
How do I set my Arlo Solar Panel (VMA4600) to power my Arlo Pro or Arlo Go camera?
How do I position the Arlo Solar Panel to get the most sunlight?
SimonFurtner
Thank you so much for the fast answer! Just one more question: How can I tell the solar charger is actually charging? Should I see the charging symbol (battery with lighting symbol) in the Arlo App when the solar charger is providing power? Or is it just a trickle charge, that doesn't trigger this symbol? Thank you, Simon
When there's enough light on the panel, you should see a lightning bolt over the battery icon.
Another aspect is that the battery won't charge if it is too cold.
  • 4 Replies
  • 3092 Views
