Activity Zones now seem to be working correctly
I just want to report that after Arlo did the cloud update that my activity zones now seem to be working correctly. I did go to the camera settings and delete my activity zones for each camera then recreated them. I also like the way the new zones has more than just the four corner adjustments It gives you a lot more flexibility in setting up your zones.
I have also noticed that I am no longer getting 300 plus recordings per night which is a big plus.
I almost lost patience and sent my cameras back but now I'm glad I didn't.
Glad your issue is resolved. Unfortunately mine is not. I'm not sure what cloud update you are talking about, I never received anything.
The cloud update was not anything you would have received. It was done on Arlo's side of things. Just by any chance have you tried deleting your activity zones and then recreating them? Not sure if that's what fixed it for me or not but they do work for me at least. Good luck.
