ARLO pro 3 security light chimes but cannot find device
Ive recently taken a light down and now it will not join the app again with the existing 3 …..Ive followed all steps heard the chime etc but then it says it cannot find the device…..any help PLEASE…. it’s driving me mad ! It’s one of the pro security lights - all the other three are fine
WHat exactly do you see? What have you tried? Is the battery charged? Is the camera still listed in Settings, My Devices? If so, try removing it from your list and re-onboard it.
Although you say its a light, @jguerdat is thinking you are adding a camera. But if you have a Pro 3, you wouldn't be scanning a QR code and hearing a chime.
Can you clarify exactly what you are trying to add back?
- an Arlo light (AL1101)
- an Arlo Pro 3 Floodlight (FB1001)
- an Arlo Pro 4 (VMC4041P or VMC4050P)
- something else?
Also, let us know if you are trying to connect it to a base/smarthub, or whether you are trying to connect it to your home wifi?
