Update won’t work
  • 5 Replies
  • 769 Views
Shcbadgers2002
My floodlight has said that there is an update when I try to update it. It continuously fails. I’ve even brought it in and said it next to my router and Arlo hub. However, it never works!
5 REPLIES 5
What region are you in? Not all regions may get the update at the same time.
That's relevant of course.  But the system shouldn't offer a firmware update if it can't deliver it.
Shcbadgers2002
I am in Louisiana.
@Shcbadgers2002 wrote:
I am in Louisiana.
Do you have a subscription for the camera?
If you do, then I suggest using phone support.  Make sure you do that using the support center in the app.  Googling for a phone number usually leads to a scam support site.
Shcbadgers2002
I do. I will reach out to them. Thanks for the help.
  • 5 Replies
  • 770 Views
