Trouble installing Floodlight
  • 5 Replies
  • 2912 Views
Chrville
Set up floodlight and on last step ap cannot find the device.
5 REPLIES 5
ShayneS
HI @Chrville
Are you still experiencing this issue?
Chrville
Yes I got the problem resolve., Thanks
CNCIT
How did you resolve this issue?
I have tried everything Arlo support have asked me to do but I am unable to add Arlo Pro 3 floodlights.
1. I am using a dedicated AP with only one SSID- 2.4GHz only.
2. AP is just a foot away
3. I factory reset camera by removing the battery, re-inserting and pressing the sync button until amber light blinks and releasing it before proceeding with the setup
4. Tried with a laptop with wired connection too.
5. On the phone app, I have disabled mobile data and used only the dedicated SSID I setup for this (2.4Ghz)
It keeps failing at Looking for floodlights step
ShayneS
Do you have any special characters or spaces in your network name or password by chance?
CNCIT
I was able to resolve the issue. Our barracuda Firewall flagged one of the sites Arlo is trying to reach during initial setup as parked site. Once I allowed parked sites, it started working. Need to find out which site Arlo tries to access besides *.arlo.com or *.netgear.com so I can only whitelist that site instead of allowing all "parked" sites/
  • 5 Replies
  • 2913 Views
