kennabt,
No. For recordings to be saved to the cloud, your Arlo Pro 3 Floodlight must have an active subscription to Arlo Smart.
kennabt,
So let me make sure that I understand correctly. My Floodlight Pro 3 will have less functionality than my old cameras unless I am forced into a subscription???
kennabt,
Legacy Arlo cameras included 7 day cloud storage for recordings (you don't mention specifically which cameras you have, but the original wire-free, Pro, and Pro 2 cameras are all legacy devices).Unlike these cameras, Arlo Pro 3 Floodlight requires a subscription for recordings to be saved to the cloud. For more information on subscription plans, take a look here: What are the available Arlo subscription plans and how much cloud recording is available?
Thanks for the info... This thing is going back. I am not paying $250 and THEN being tied into a plan to actually use. STUPID!!
Well, it is explained that the plan is required after the trial. The idea that there's even a trial indicates that something is needed afterwards.
