SUbscription Plan is not available
Hi,
I have pro 3 floodlight purchased from US, i installed it in my country Azerbaijan however can not get any subscription plan. Any idea how can i get it? Thanks for support.
Rashad
The place of purchase doesn't matter - it's where you set them up. If you had set them up in the US and used a US credit card you could then have moved the system to your home and have it work. Unfortunately, there's no easy way for you to now be able to get a subscription which is limited to only certain countries.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
Arlo Pro 3 Floodlight
