Ive just noticed recently that the battery icon for the floodlight camera shows red with a lightning bolt in the app. Is this new or indicative of a problem? Thank you in advance for your responses.
For more information on battery status icons, take a look at the definitions found here: What do my Arlo camera's battery level icons and notifications mean?
New and a problem which rather seems like a backend thing since it happens to both apps and the web client. I have this, too.
The red icon with the lightning bolt is an indication that a charger is connected but no actual charging is taking place. In these cases, it means your solar panel is connected and functioning correctly but it's not charging the camera (likely because it's not in direct sunlight or it's night time). We're working on getting our documentation update to reflect this new icon behavior.
It shows the new icon regardless under v3.5.4, day or night. In the previous versions on the iOS app, it was the old standard icon with the lightning bolt and at night would just show the battery, with no lightning bolt. Currently, the batteries continually show > 95% so i assume it is charging. I updated my other iOS device to 3.5.4 and it now shows the new red battery with lightning bolt at all times as well.
Hi James,
I also have this red charging battery icon regardless of day or night. I have this behavior on the android app and the web application.
I think there may be a UI bug regarding this newly introduced red charging icon.
What did you have to do to make the battery icon display correctly? My Pro3 floodlight is also connected to a solar panel and I'm getting the red charging battery icon (no matter if its day or night)
Okay, so I unplugged my solar panel from the pro3 floodlight camera, waited about 45 seconds, plugged it back in and now I have the green charging icon that I used to have. Hopefully that helps someone else
The camera is connected to the Arlo solar panel and I can confirm that charging works as it always did.
I tried removing the battery and reconnecting the charging cable, didn’t help.
The camera and the solar panel are both new, I installed them about 6 weeks ago.
Is there a malfunction I should worry about or is the app simply showing the wrong icon?
Most likely neither.
Arlo changed the icon a few days ago. The red icon now means that the floodlight is connected to a charger (or panel), but is not actually charging at the moment. So you will see the red icon at night, or if the battery is already full.
Arlo: Please review this issue further. It has only been an issue since updating my app to iOS 3.5.4.
@BV96 wrote:
Why is my Arlo pro 3 floodlight camera that is connected continuously to an Arlo solar panel facing direct sunlight west say it’s 100% charged but highlighted in red with lightning bolt?
Based on earlier mod responses in this thread, it is showing red because the battery is not charging (since it is 100% charged already). Very confusing, and either there is an omission in the kb article or a bug in this particular situation.
https://kb.arlo.com/1179176/What-do-my-Arlo-camera-s-battery-level-icons-and-notifications-mean
Arlo Pro 3 Floodlight
