  • 4 Replies
  • 1541 Views
Tinman54
I am having trouble connecting my Pro 3 Floodlight to a new 4045 Smart Hub.  After going thru all steps to add the Smart hub to my account and then add the Floodlight camera, the Floodlight camera shows a live feed on the Arlo account, but no recordings. Also going to settings, the camera shows connecting to wifi, not the Smart hub. How can I connect the camera to the Smart hub and not wifi and maybe get recordings. Don't want a subscription to cloud service.
Have you checked the subscription status?
You should see the option of connecting the camera to the base in the setup procedure.  Can you confirm that you did see that option (and of course used it).  No QR code scan would have been needed.
Tinman54
Yes, went thru steps to connect camera to the hub with no QR code.
Then your issue about "the camera shows connecting to wifi," is resolved?
Tinman54
With assistance from Arlo support chat, I was able to connect the camera to the new smart hub not wifi. Don't have Subscription to cloud storage and don't want it.   Problem not solved yet because new hub does not have local storage like old base station. New smart hub does have USB port to add local storage. Need to get new thumb drive to hopefully solve issue.
  • 4 Replies
  • 1542 Views
