Pro 3 Floodlight - How to reduce wind noise activations?
  • 5 Replies
  • 2063 Views
BTG
Medium windy last night and 98 activations from Audio. Under Mode/Armed/ If Motion or Audio on Floodlight Camera settings, AUDIO DETECTION SENSITIVITY turned all the way down (left on scale) to 1, but still tripped 98 times in 6 hours. Any thoughts?
@BTG wrote:
the Audio Detection Sensitivity under Edit Mode / Edit Rule / Audio Settings, is turned all the way down to 1. How do you turn it off?
You uncheck "Audio Is detected" in the rule.
5 REPLIES 5
dcfox1
Since you have the audio setting at it's lowest unless you really need the Audio alerts you should turn it off in your Rules as it will drain the battery fast.
BTG
The microphone is turned off under, My Devices / Floodlight Camera  Settings / Audio Settings and the Audio Detection Sensitivity under Edit Mode / Edit Rule / Audio Settings, is turned all the way down to 1. How do you turn it off?
dcfox1
Here is a link to the Mode and rules to show where you uncheck it to turn it off.
About Arlo Modes and Rules
BTG
  • 5 Replies
  • 2064 Views
