My Floodlight is not charging. Shows
- Email to a Friend
I bought an original outdoor charger for my floodlight. Once I plugged in it was at 49% and a orange triangle with the charging sign was showing next to it. 3 hrs later I checked on it and the orange triangle still there but it dropped to 45%. I don't know what to do
Model: FB1001 | Arlo Pro 3 Floodlight
- Email to a Friend
Assuming the ambient temp is below freezing, even the external charger won't charge the battery due to li-ion batteries being protected from charging. Warming the camera/battery should allow charging to resume.
- Email to a Friend
Thank you for the respond. So me living in the Poconos where winter temp drop at 0 or negative almost every night, would mean that this equipment might not be the right thing for me.
- Email to a Friend
I'm in Rochester, NY so temps in the winter are frequently below freezing. The battery will keep things working down to -4F - it's just that the charging can't happen below 32F. You can always bring the camera or battery indoors to charge if you need (a spare battery with the external charger would work the best) but the battery should last long enough for temps to rise to the point of allowing charging.
