Multiple Arlo Pro 3 Floodlights randomly freezing up
  • 1 Reply
  • 682 Views
  • 1 In Conversation
Hardcam
We have multiple Arlo Pro 3 Floodlights setup at different houses and they all experience the same issues of running fine for a week or so and then they lock up.  The motion sensor will still work and the light will come on however the video is frozen and image in the app is from days ago when the camera initially locked up.
I opened a ticket with support on the issue already and no luck.  They suggested changing the Wifi channel that my router uses to avoid congestion... well this issue is happening at not only 1 location but 3 different locations with 3 different routers  that all have minimal to no other devices connected to them.  I don't really want to switch to a hard wired CCTV solution but that might be the next route if these issues persist with the arlo products.  Anyone else having similar problems?
Hardcam
Looks like a firmware update was released recently for one of them.  Going to see if this resolves the issues.
  • 1 Reply
  • 683 Views
  • 1 In Conversation
