× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
How to do a Factory Reset of Arlo Pro 3 Floodlight?
  • 1 Reply
  • 182 Views
My Arlo Pro 3 Floodlight Camera disconnected from my wifi network yesterday and now I can't get it to reconnect. I saw in the user manual it says I should be able to press the "sync" button on the device for 12 seconds and it should do a factory reset. I've tried this numerous times but it doesn't seem to work. Am I missing something? Is there another way to get it to reset - or better yet, reconnect?
I'm trying to re-add it to my network using the Arlo app, but it's not seeing the QR code, which is why I'm trying to do the reset.
Thanks for any advice!
hasinketi48,
You should be able to complete a factory reset by holding the sync button for 12+ seconds. If you're having trouble, try charging the battery first and then attempt the factory reset again.
  • 1 Reply
  • 183 Views
