How long does the rechargible battery in a Arlo Pro 3 Floodlight last until you have to recharge it?
  • 1 Reply
  • 1123 Views
scminer
"It depends." (TM)
Usage is generally defined as <5 minutes per day of recording and live viewing. Of course, floodlight usage at night will also get in there. If there are relatively few recordings per day, the battery should last a couple months or perhaps even more. Use of a solar panel or the outdoor AC charger helps negate the issue.
  • 1 Reply
  • 1124 Views
