  • 14 Replies
  • 13579 Views
melaniejmccann
Please help! I've set up my Floodlight without an Arlo Smart subscription and it is detecting motion and sending almost instant notifications, but the floodlight isn't activating. I've checked the rule in 'mode' which is correct and the light test worked well.
The most confusing part about this is I had initially set this up with the free Arlo Smart trial this morning and the light was working fine. But I was getting a big delay on notifications, so decided to cancel the subscription to see if the person detection feature was slowing it down (which it clearly was). But now the floodlight isn't working.
I should also add that I've unpaired and repaired the device several times, removed the battery for a few minutes before replacing it, and tested the manual floodlight activation which also worked fine.
Any help would be much appreciated.
For those experiencing this issue, take a look a the troubleshooting listed in the follow article: https://kb.arlo.com/000062731/What-to-do-if-the-Arlo-Pro-3-Floodlight-will-not-turn-on-when-motion-i...
14 REPLIES 14
Since you've already done what I would suggest, use the Contact Support link at the bottom here.
melaniejmccann
Ok will do - thanks.
michaelkenward
Sensei Sensei
Sensei
Without seeing the rule, we have to take your word for it, but remember that with the Floodlight you have to trigger you have to set it to turn on the light as well as the camera.
Floodlight control rulesFloodlight control rules
And, of course, the light won't work during the day.
This is a feature that people have requested for the Ultra and Pro 3 cameras, where you have no control over the light.
Just another user
melaniejmccann
Thank you for your reply. I spoke to Support yesterday who tried to fix the issue but recognized there was a problem. They've raised a case so hopefully someone gets back to me soon.
melaniejmccann,
Are you testing this at night or during the day? Depending on the amount of light in the environment, this could be the reason the floodlight is not engaging. Take a look here for more information:
What is the Dusk to Dawn sensor setting on my Arlo Security Light?
melaniejmccann
Thanks JamesC I have tested both during the day with the dusk to dawn setting at max light and at night.
Appreciate your reply.
melaniejmccann,
Okay thanks for checking. Please let me know the results of your support ticket and if you need any further assistance.
melaniejmccann
Hi James. So I never got that call back about my case. But then the floodlight randomly started working. And the notifications were instant. I was happy. However a few days later the delay started again and I realised Arlo Smart had been reactivated - even though I'd cancelled my subscription (purposely to avoid the notification delay). Obviously had been done in the back end. And now my notifications have totally stopped happening.
Can you help? I'm tempted to take the device back to the store for a refund.
Many thanks
Melanie
melaniejmccann,
If you successfully cancel Arlo Smart. It should not automatically reactivate. What process did you use to cancel? Have you tried again?
melaniejmccann
Thanks James - I followed the instructions here - https://kb.arlo.com/1215141/How-do-I-change-or-cancel-my-Arlo-subscription-plan and successfully cancelled it. It evidently went through because from that point videos were no longer recorded. And now my recordings only go back as far as June 10 - when it automatically reactivated.
Melanie
melaniejmccann,
Have you tried this again?
melaniejmccann
Hi James
No I haven't. I don't really think I should. I now have so many questions - how my subscription could reactivate without my consent and why no one has called me and why I'm now getting no notifications at all.
I really appreciate your help but I'm at a loss at what to do at this point. Ugh.
Thanks for your help.
melaniejmccann,
I've opened a new support ticket for the issue you're experiencing and have escalated that ticket to the support team. An agent wlll reach out to you to gather more information shortly.
  • 14 Replies
  • 13580 Views
