  • 4 Replies
  • 1345 Views
ososos11
Issue:
Almost weekly one or both of the following happens:
  1. Light does not come on when motion detected
  2. Video does not record when motion detected
I either get one or both of the issues.
Resetting  and restarting it works for a few days until it reverts to the light not coming on, then usually stops recording intermittently.
I do have an active subscription and other arlo cameras which work fine.
Any ideas on how to get hold of support?
It is marketed as a Floodlight Security Camera of which it does neither for me with which I could rely upon..
I have tried to contact Arlo support multiple times but my tickets get closed. I have tried to call the help line but get cut off everytime. Live chat also ends automatically after a long wait.
I have had the floodlight for almost 2 years.
ShayneS
Hi @ososos11
Do you mind private messaging me with your most recent case number and I will look in to this for you.
Thank you
ososos11
@ShayneS How can I private message you? I don't see an option.
ShayneS
@ososos11 If you select my name, you should be able to see a "send this user a private message" on the right hand side midway through the screen.
ShayneS
I have notified support and someone should be reaching out to you as soon as possible to help with your concern.
  • 4 Replies
  • 1346 Views
