Floodlight Pro 3
  • 5 Replies
  • 3172 Views
Dignan76
My floodlight went offline and is not reconnecting.  I have the slow flashing blue light.  Reset with sync button did not work.  I bought the floodlight at Best Buy so it is not being recognized on my Arlo account so I cannot even sign up for one of their security plans to get live support.
5 REPLIES 5
Remove the floodlight from Settings, My Devices. Reset it by holding the small hidden button for >15 seconds, until the LED flashes amber. Onboard it again normally.
Dignan76
I tried that. The amber light never comes on. This worked for me previously after the floodlight went offline but is no longer working. Seems stuck in an offline mode.
Dignan76,
I'd recommend making sure the battery is fully charged and try the factory reset procedure described above again. Go through the onboarding as if the camera was new and report your results. Are you still experiencing the same issue?
Dignan76
Thanks James. Yeah I tried that as well. It seems the factory reset procedure isn’t taking. No matter how long I hold down the sync button it never blinks red, or at all. Just a slow blue blink on a different LED. Battery is full charged and the device has been unpaired. I even tried deleting and reinstalling the app.
Dignan76,
I've opened a support ticket on this issue, you can follow up on this ticket using help center within the Arlo Mobile app.
An agent should be reaching out to you soon to gather more information.
  • 5 Replies
  • 3172 Views
