× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
Floodlight Charging Cable
  • 1 Reply
  • 91 Views
ahleyjohn38
My wife was doing some house cleaning and ended up misplacing the cable for the floodlight charger. I have the wireless doorbell but I was wondering if the connection is the same? I think I switched it out when I charged it between the two because it’s just used the usb c adapter.
The Pro 3 floodlight or the standalone security lights? The former uses a magnetic cable so won't be interchangeable but the latter uses the same microUSB connection so the doorbell charger MAY work. That's because there can be issues with how the plastic surround on the cable and/or the camera (or light) allows the connection to be fully made. You'll have to try it to verify - if there's blockage, just try a different cable.
  • 1 Reply
  • 92 Views
