  • 40 Replies
  • 4169 Views
  • 5 In Conversation
Andersonnmbr2
Each night, sometime around midnight, my Arlo pro three flood light turns off as if I turned it off manually in the app.  Every morning, I have to go into the app and manually turn the flood light on.  Is this a known bug and how do I fix the problem?
40 REPLIES 40
Do you mean they are Disarmed or that the floodlight itself is disabled? Are you using schedules and have checked them for proper settings?
Andersonnmbr2
If I go to device settings in the app, it shows that the device is off even tho I didn't turn it off. I have no schedules set up. In addition, it doesn't flag motion unless a subject is close.
Use the app to go to Settings, Support and select your camera. Scroll down to Contacts to see what official support says.
Andersonnmbr2
They said to factory reset the device.
That's a usual troubleshooting step. Did it work?
Andersonnmbr2
We shall see, day one and it did not randomly shut off but I'm still holding my breath.
Andersonnmbr2
Factory reset did not work.  It has turned off twice since the reset.
Punjabiboy21
I have the same exact problem!
Andersonnmbr2
Unfortunately support still hasn't identified the problem. Did factory reset fix your issue?
BrookeN
Are you on iOS or android? Can you please provide the firmware you are on as well?
Andersonnmbr2
Android and I have the latest firmware update as of this Friday.
BrookeN
Thank you for providing that information. I have passed it onto our development team. I will update that community as soon as possible.
Andersonnmbr2
Thank you
BrookeN
Are you still seeing this same behavior? Are you talking about the light turns off or the whole device? And is there any other device that this is happening to?
Andersonnmbr2
The whole flood light turns off. My other cameras are working as expected.
Punjabiboy21
Yes. Still having this issue. Whole device turns off at midnight
BrookeN
It appears that Smartthings may be causing some of this behavior. Can you double check what automations are set up for this camera in Smartthings?
Andersonnmbr2
Sure, how do I check for automation in smartthings?
BrookeN
Automations can be found in the Routines tab of the SmartThings app, and are divided into Manually run routines and Automatic routines. Rules are represented as Automatic routines in the app.
Andersonnmbr2
Thanks, there are no routines set up in smart things.
BrookeN
Can you both please enable Smartthings support
Go to SmartThings Web (my.smartthings.com)
  • Log in to your Samsung Account
  • Select Menu (⋮) and choose Settings
  • Toggle on Account Data Access
  • Select the time period and confirm
Andersonnmbr2
Thank you
BrookeN
@Andersonnmbr2 did you go through those steps?
Andersonnmbr2
Account data access was not turned on. Are you suggesting that I turn it on?
  • 40 Replies
  • 4170 Views
  • 5 In Conversation
