  • 19 Replies
  • 2079 Views
  • 2 Likes
  • 6 In Conversation
Scotte1975
I had an Arlo floodlight for the last 2 years or so all worked fine until it fell down and had to be replaced, I bought a replacement but it won’t join my wireless network I scan the QR code and nothing happens.  I have a Sky home hub and it works on both 2.4 GHz and 5GHz on the same SSID this is the same hub that was in place when the original floodlight was setup.  I’ve tried creating a separate SSID for 2.4GHz and forced the iPhone I’m using to setup the device to use that new SSID but the floodlight still won’t detect from the app, I’m a infrastructure professional by trade so I’m quite confident the config I did in the router was successful, any ideas would be greatly appreciated - currently digging out a 10 year old iPad to try on a device that probably only uses 2.4…
19 REPLIES 19
Scotte1975
Update - tried really old iPad still got the same issue
Are you hearing the chime after the QR code is scanned?
If you are, then also check to see if the camera is in the router's attached device list.
Scotte1975
Yes hearing the chime then nothing happens blue flashing light stops flashing then device isn’t detected, no obvious sign of the floodlight joining the network on the router list of connected devices I have a couple of unknown devices though how do I check MAC address of floodlight?
I don't recall if the MAC address is printed on the label inside the camera or not.
One (likely faster) option is to take a screen shot of your connected devices before you do the install, and then see what changed later on.
It'd be useful to know if the problem is that the floodlight can't join your wifi network, or if the problem is that the app can't discover the floodlight after it joins.
Also, you might try adding the floodlight using a PC (my.arlo.com).  If you can connect the PC to the router with ethernet, then I suggest doing that.
Scotte1975
Thanks I’ll try the PC option, this is the second new floodlight that has done the same thing I returned the first as I thought it was faulty, I suspect that since I installed the original floodlight Sky have updated my router remotely to add 5Ghz support, the original floodlight that I had to replace because some birds knocked it down installed fine first time
BrookeN
@Scotte1975 thank you for proving that information. Support will be reaching out to you as soon as possible.
Scotte1975
Unfortunately it seems as if the floodlight is basically incompatible with my Sky Q hub, which is strange because it’s the same router I had previously set a floodlight up on. Tried having Sky configure 2.4Ghz for me but still the same issue. Having to request a refund
  • Did you try "add device" for both the app and a PC (my.arlo.com)?
  • Did you check that WPA2 (AES) connections are allowed in the router (not requiring WPA3)?
  • Any VPN on the phone or PC also need to be disabled before the install.  Sometimes disabling AV and internet security software on the PC is needed.
If you are getting to the "chime" step, then look at the router's attached device list, and see if the camera is connected to the hub wifi.
Scotte1975
Hi,
im getting the chime, but the floodlight then won’t connect to my wireless network, it doesn’t appear in the connected devices list on the router.  Authentication is set to WPA2-PSK (AES), I do t have a PC I can use to do the setup only phone/tablet
Scotte1975
Also not using a VPN on my IPhone
Ok.  One last thing would be to try the hardware reset.  The process is to open the camera and hold down the sync button inside until the LED flashes amber (~15 seconds).
Scotte1975
Already tried that multiple times
 Exchanging the camera might be the next step then.
Ranks115
having the same problem. With this last cold snap - my camera went off-line. Wireless camera. Can get the chime, but then the camera is not detectable and can’t be added to my system. I don’t wanna have to buy a camera every two years. Any suggestions?
djames123
I’m having the exact same issues as above. New App won’t let me add my second Floodlight 3 after not using it for a while as we moved house. I wanted to add it to a second location. The QR code makes it chime. Then when it searches it fails. Done the sync reset 3 times now and about to give up. If you solve scotte1975 can you post the solution please.
Scotte1975
Hi All,
Not the answer you were probably looking for but I was in contact with Arlo support and we couldn’t fix the problem, make sure you are connecting to a 2.4GHz network this seems to be crucial. But I’m afraid even getting my ISP to check my WLAN settings wouldn’t fix it.  Ended up getting a refund and buying a Ring floodlight instead the light is nowhere near as bright but at least it connected to to my network
Have you tried rebooting your router or hub? Sometimes that makes a difference.
Scotte1975
Yes tried literally everything, rebooting router, resetting floodlight, changing WLAN settings to recommended setting by both ISP and Arlo, even tried joining the floodlight with multiple different devices
Ranks115
Same, rebooted router, tried a different phone / computer. Flood light crapped out in less than 3 years. Don’t know if it’s the battery or the light, but not up for spending a bunch of $$ on crap. I’ll be switching to Ring as well.
  • 19 Replies
  • 2080 Views
  • 2 Likes
  • 6 In Conversation
