Battery Full Charge indoor USB
  • 2 Replies
  • 665 Views
BrianMoon
How  can I tell when the battery on my Pro 3 floodlight is fully charged when using the indoor USB charger? There don’t seem to be any lights on when it is plugged in.
Check the camera settings to ensure the Indicator LED setting is enabled? The LED should blink blue briefly when power is applied and eventually turn solid blue when charged. The floodlight battery is the large variety so it may take 6 hours to charge.
Also, make sure you are using the microUSB connector inside the camera to charge the floodlight.  The magnetic cable won't work with the indoor charger (you need the outdoor charger for that camera).
  • 2 Replies
  • 666 Views
