Arlo pro 3 floodlight
  • 17 Replies
  • 3202 Views
Angela706
I have put a new battery in the camera floodlight and I put it back in the mount and it works for 5 mins at the most and it cuts off saying battery is dead too low to operate and that’s my second battery put in . Any suggestions on what’s wrong?
@Angela706 wrote:
the app isn’t helpful to get to support
Actually it is the way you are supposed to use.
If you see "Library" in your app, check this out:
If you see "Feed" instead, then check this out:
@Angela706 wrote:
I went through their website
https://my.arlo.com ?
17 REPLIES 17
Well, it could be a
  • camera failure
  • charger problem
  • two failed batteries (unlikely)
What are you using to charge the batteries?
Angela706
I’m using the plug/ cable it came with to charge it
Is the cable using the magnetic connector on the outside of the housing?
If it is, try using a microUSB cable (connecting to the same charger).  Open the housing of the camera, you will see the microUSB port inside.  Let it charge for some hours - you should see a solid blue LED on the camera face when the battery is fully charged.
Angela706
I’m using the microusb to charge it till blue led is lit up and then putting it back outside. It’s only lasting like maybe 5 minutes if that before it cuts off saying battery is too low. All suggestions appreciated and thanks for those u did .
Angela706
Still isn’t working, still says battery dead when it’s 100% . Anyone have other suggestions would be appreciated
Obviously something is wrong - no way to tell whether it is with the camera or the battery.
Is the floodlight still under warranty?
Angela706
It is out of warranty
BrookeN
@Angela706 please reach out to support for further assistance. Click on the silhouette on the top ~ Support Center ~ Contact Support ~ it will ask you questions regarding what you are needing support for and then support will reach out to you.
Angela706
I reached out to support but it came down too I don’t pay for support option so I guess I’ll keep trying
BrookeN
You have a subscription on your account. So you should already be able to reach out to support.
Angela706
That’s not what they said I’d have to pay extra for support option and yep out of warranty but would be nice to have a k5 pro floodlight like the other ones, don’t think the floodlights have been updated in awhile, may look else where for a floodlight camera. Thanks for all the help given.
Angela706
That should be 5s pro sorry type o
BrookeN
Are you reaching out to support through the app on your phone?
It sounds like you reached a scam support site.  That often happens when people google for a phone number.
That is why @BrookeN wants to know if you used the support center in the app (or not).
Angela706
I went through their website the app isn’t helpful to get to support
Angela706
I’ll try going through what u sent me
  • 17 Replies
  • 3203 Views
