Arlo pro 3 floodlight - no rec
  • 5 Replies
  • 98 Views
ReneBo
Hi everybody.
So after my free subscription ran out on my Pro 3 floodlight it has stopped saving records locally even though I got usb in my base. I tried restarting the base, but no luck.
Any pointers?
Thanks!
Model: FB1001 | Arlo Pro 3 Floodlight
@ReneBo wrote:
Hi everybody.
Note you can't make manual recordings, but it still should be saving motion alerts (if it is actually paired with the base of course).
Did you also try restarting the camera?
Also try a different USB drive.
ReneBo
Cam also restarted yes! I will try another usb
It is only the motion recording im reffering to.
ReneBo
So new USB mounted, but still no recording when motion detected. Somehow I believe it's connected with the subsciption running out since it happened there.
I should be getting recordings on USB even though no subscription right?
While you should have gotten an error message when formatting the drive in the base/hub, make sure it's at least 16GB - less won't work.
Yes, you should get local recordings without a sub.
  • 5 Replies
  • 99 Views
