Arlo pro 3 floodlight - battery replacement
I am looking to get another battery for my floodlight. Can it be a standard battery or does it have to be the XL?
Also does anyone know the rating of the dl battery?
https://ukshop.arlo.com/product/arlo-rechargeable-battery-white-2/?gclid=CjwKCAjwo4mIBhBsEiwAKgzXOOE...
@aharman wrote:
Also does anyone know the rating of the xl battery?
@JamesC - I think that info should be added to this kb article: https://kb.arlo.com/290/What-kind-of-batteries-does-my-Arlo-camera-use As an aside, there is a small typo in that article (free is spelled as freee in one spot).
Not sure, and it would be useful to know. However, if it does work, it would still be best to use an XL if you have the floodlight enabled.
Arlo Pro 3 Floodlight
