Arlo pro 3 floodlight battery does not update
The camera itself works fine but the battery doesn’t update on my iOS device. I have a solar panel attached to it as well. During the nights it shows that the device is charging without sunlight. I disconnected my device from the solar panel from 100% it updated to 69%. It kept showing 100% charge and it only updates when I disconnect it and after a few minutes it’ll update.
Any suggestions?
Mirosees,
If you log out and log back in, does the battery life update?
I tried logging out and back in.
Tried it but didn’t work
Arlo Pro 3 Floodlight
