Arlo Pro 3 Won't Update Firmware
Are you in field trials (kinda like the beta program but not really) that would get firmware updates before anyone else? The latest released firmware for the floodlight is 1.080.26.5_58_3b3ef75 (see https://community.arlo.com/t5/Firmware-Release-Notes/bd-p/arlo-release-notes and look for the Pro 3 floodlight) - is that what version is already installed?
This is happening to me as well on my Arlo Pro 4 … not sure what to do.
Try rebooting the router and/or hub (if so connected). Reboot the camera if connected to WiFi or reinsert the battery to get to known settings. Worst case, remove the camera from your account and add it back in.
You could also just wait a day or so, and see if the firmware updates on its own.
Yes I spent several days trying repeatedly to update the firmware on one of my three cameras. Turns out while it was showing 85% battery it was actually totally dead. When I brought it in (after restarting the base station to be sure), plugged it in, charged it fully, and tried again it finally worked. First time this has ever happened and my bf was about to throw the whole kit in the fire after so many failed attempts. Seems to be working after this “fix” though. Not sure if that will help, just wanted to let you know I did have a similar issue recently.
Arlo Pro 3 Floodlight
