Retired_Member
Not applicable
2022-01-05
09:55 AM
I have the solar panel connect with the Arlo Pro 3 Floodlight. Now, the app shows camera offline. But if I unplug the solar panel, the camera back to works again. Why if I plug the solar panel back then the camera not working?
Retired_Member
Not applicable
2022-01-13
05:28 AM
I end up get a arlo outdoor charger (25' Outdoor Magnetic Charging Cable for Arlo Ultra and Pro 3 Security Cameras), now the camera is charging. THE PROBLEM SOLVED!
(didn’t know they have outdoor charger too, I thought solar panel is the only way to charge outdoor).
Kind of waste money, but at least it’s working now. I don’t know what’s the problem with that new solar panel, i tried every ways people mentioned on the internet but still not working. I feel maybe this product they make from design to charging just not that perfect yet.
5 REPLIES 5
Could be a bad panel. Can you try it on another camera? DO you only have the one panel? The fastest resolution may be to swap at the store.
Retired_Member
Not applicable
2022-01-06
10:17 AM
I only have one camera, and the solar panel all new. Now If I plug the solar panel back in to the camera, it’s offline again, not working.
The app shows “Your arlo device appears offline. Please make sure it’s powered on and connected to the internet.”
I'd swap at the store.
Retired_Member
Not applicable
2022-01-13
05:28 AM
Try putting the light into the housing and then connecting the magnetic cable. Connecting the cable first will charge the battery but the camera will not function.
