Arlo Pro 3 Floodlight questions?
Anyone have an Arlo Pro 3 Floodlight? How strong is the light? My wife made a comment the other day that our main camera in the center of the garage looks very pixelated at night. It's set to highest video quality and the spotlight is turned on. I also have 2 normal outside house lights surrounding it.
I'm guessing those 3 lights combind are just not good enough. That Arlo is wired to power so not concerned about it running out of power if I switch to the Floodlight model.
Maybe try turning off the spotlight and low color - and just use IR (Nightvision) for nightime recordings.
The Pro 3 floodlight is quite bright - and covers a much larger area than the spotlight.
- 2000 lumens with rechargeable battery
- 3000 lumens with outdoor charger
