Arlo 3 floodlight won’t record or notify
Device no longer detects, records, or notifies for motion. Tried restarting and also tried removing the battery then installing like another post suggested. Worked for a day and now it doesn’t do it again. I can manually view though.
Have you checked the camera mode to make sure it is armed?
Can you make a manual recording when viewing it?
Yes it is in the correct armed mode and I can manually record while viewing. I’ve gone through the menu and settings to make sure every setting is right. I think it just needs ti be replaced at this point.
Start by removing and bre-onboarding the camera to see if that helps.
Arlo Pro 3 Floodlight
