Anyone know of a 2-in-1 gutter mount for the Pro 3 Floodlight and the Arlo solar panel charger?
  • 1 Reply
  • 1723 Views
Gordon391
Hi everyone,
Brand new owners of the Arlo Pro 3 Floodlight camera and Arlo Solar Panel Charger (2021 Released) from Amazon.  We also, on the same order, bought the Wasserstein 2-in-1 Universal Gutter Mount for Camera & Solar Panel for Wyze, Blink, Ring, Arlo, Eufy Camera. Too much of a noob to realize the difference between the reference to Arlo and the specific mounting of the Arlo Pro3 Spotlight Camera, we're thinking that mount will need to be returned.
We also cannot seem to find even a "single" gutter mount for the Arlo Pro3  Floodlight camera. New siding and roof is really making us hesitant to pierce either surface. Any ideas or suggestions?
Thank you in advance for any and all help.
Both the camera and panel have threaded mounts that will allow the gutter mount to screw into (it's just a camera-standard 1/4"-20 thread). If you happen to have a camera with a security mount (you mention the camera being both a floodlight as well as spotlight, which are decidedly different from each other) you would possibly need to buy a different battery cover but first we need to be sure whether you have the security mount. In any event, as long as you have a threaded socket at the back of the camera, these mounts would work.
If needed, a quick search on Amazon for "camera gutter mount" shows a variety of choices, including single mounts.
  • 1 Reply
  • 1724 Views
