Adding new Arlo pro 3 floodlight camera to Arlo smart plan
  • 1 Reply
  • 1350 Views
SRSCA
I had 5 cameras connected to my case station. I removed one of the Pro 3 cameras and connected my new pro 3 floodlight camera. How do I now add the floodlight camera to my Arlo Smart account? If I leave it in trial mode, no recordings are kept.
You can always cancel your trial but the problem seems to be something else since the trial works like the subscription. Smart does make a determination by the servers as to whether to keep or discard the videos based on your settings so check there for the floodlight. I would also set up local recordings so you can compare the cloud to local since the local recordings are never discarded. Make sure your modes and rules have the floodlight included and appropriate settings so recordings are made.
  • 1 Reply
  • 1351 Views
