ARLO Pro 3 Floodlight won’t sync even manually
Therefore removed the device from the app. I can now not add the device to the app. (Both phone and floodlight set you the same WiFi connection) The app will not sync with the camera (I am not using a base station or hub).
I have tried everything. Any ideas please?
Sounds like a faulty floodlight. Either swap at the store or use the Contact Support link at the bottom here.
Shazbod,
Have you factory reset the floodlight before attempting to go through setup again?
To factory reset, press and hold the sync button for 10-15 seconds, allow the camera to reboot and try again.
I then tried removing the battery and putting it back in and it reconnected and worked. It then disconnected again and I did the same thing and agin it worked. It is therefore a problem with the battery or the battery connections within the unit itself? What do you think? Thanks Sharon
Shazbod,
This could be an interference or range issue. How far away from your router is the camera? What does the signal strength indicator show?
It was therefore nothing to do with my WiFi it is definitely a problem with the camera software.
MakersQuarter,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Pro 3 Floodlight
